Very easy if you have a proper synthetic rope with the correct attachment. It’s a straight swap.How hard is it to replace wire cable to nylon on a Warn XD9000 winch
Do people with low mounts like the XD9000 have a synthetic option then?The winch ropes are polyethylene, not nylon, which is unfortunate as far as heat is concerned because nylon melts a hundred degrees higher than polyethylene. Damage to the dyneema rope from the heat of the winch motor is definitely an issue. Do a web search on "melted winch rope" and you will get lots of hits.
The XD9000 was available as an XD9000-S direct from Warn at some point, but I think it has been discontinued.Do people with low mounts like the XD9000 have a synthetic option then?
Heaps of options. You just have to be careful and take your time.Do people with low mounts like the XD9000 have a synthetic option then?
Any personal recommendations mate?Heaps of options. You just have to be careful and take your time.
I'll point out that most of the cases of heat damaged Dyneema don't result in the rope breaking but I have no doubt the capacity of the rope is reduced.
If you want quality get a Warn. If you want cheap and cheerful get a Kings. For something in between try a Carbon or Runva. Hard to recommend something without knowing your priorities.Any personal recommendations mate?
Looking for something under $200ish that will be reliable when I need to use it once a yearIf you want quality get a Warn. If you want cheap and cheerful get a Kings. For something in between try a Carbon or Runva. Hard to recommend something without knowing your priorities.
This looks the goods thanks mate 'Carbon Winches Australia 24m x 10mm Synthetic Rope Spliced with thimble'If you want quality get a Warn. If you want cheap and cheerful get a Kings. For something in between try a Carbon or Runva. Hard to recommend something without knowing your priorities.
Under $200ish? Well 30m of 10mm Dyneema winch rope is normally $199 but currently on special for $139.Looking for something under $200ish that will be reliable when I need to use it once a year
Sent from my Pixel 2 XL using Tapatalk
