1 - 2 of 2 Posts
I am having a oil leak at ther rear oil seal of the transfer case. It is only a few drop when stationary but I suspect it leaks while in motion. The rear of the chassis and diff is cover with a bit of oil.
Can anyone tell me how to remove the rear oil seal? Do I need the special tool or just ply it out with flat screw driver? Do I need to drop the oil first? What size is the nut to removed the rear flange?
The parking brake is not very effective now because of the oil contamination, can I clean it with brake cleaner or I have to replace the shoes.
Thanks in advance....
Go Hard or Go Home
Transfer Rear seal replacement
This is what it shows in the Electronic Service Manual.
As for socket sizes, I have no idea mate. and a couple screw drivers should be suffice to remove the seal if your carefull.
And remove the hand brake shoes, inspect them & decide whether they need replacing.
1 - 2 of 2 Posts
