How do you pull the crank out with a clutch or an auto attached to it?
Yeah, that makes sense.
That was very long time ago. I don't think we pulled the crank shaft out or may be he did.
I was a helper & didn't know anything about cars back then.
I think the scenario must have been different.
Gearbox might have been pulled out already for other reason, and perhaps he decided to replace the rings(he did some other stuff inside as well, that I can't remember)
So, I don't think he put the car on the hoist just for the reason of replacing piston rings.
That would've been a pretty back breaking way to go for that job.
But, it still was a back breaking job from what I remember.
Honing tool is pretty easy to get.
I guess I'm going to have to do some homework on how to use it properly and the measurements and stuff.
So, if I understood you correctly, it's not a simple quick job to pull the pistons out one by one from under the engine and replace the rings!
It's practical to pull the motor out and do a complete rebuild job properly.
If I presume re-boring is not necessary, then honing can be done with a honing tool and oil.
I'm praying the cylinder bores are perfect circles, no deep scratches and don't need re-boring.
If they do, then I might have to put off the back breaking whole rebuilding job as a slow moving back yard job, while I'm getting a low km replacement motor.
Well, that's pretty much how my diff rebuild job ended up.
Cylinder bores looked good cosmetically(though pretty shiny) when pulled the head out last time. I couldn't see any scratches at all, but that was over two years ago.
So, honing the bores sound like a good idea.
I'm not sure whether I can source the bearings(and rings) for a good price, to make the job worthwhile.
