1 - 8 of 8 Posts
Another option is Unichip, which is a piggyback chip. Where you located? The VTC bit suggests somewhere in the Gulf
You can have any ecu installed to control certain things in even the most sophisticated cars.
Just depends how deep your pockets are.
If you wanted fuel injection, ignition timing and cam control taken over then you just let the factory ecu think it is still in control while routing these signals through to the aftermarket ecu.
The unichip can modify cam timing signals and also manifold flaps etc.. all for a fraction of what a full aftermarket setup will cost.
1 - 8 of 8 Posts
