1 - 7 of 7 Posts
Hello out there.
I am thinking about putting air rite bags under the patrol ute ??
Has anybody fitted air bag suspension If so how hard was it and what kit did you use.
I have been looking on the net and cant seem to find which kit to use for a 2 inch lift.
Any suggestions would be greatly accepted.
Thank You
nissan safari
i priced them up a while ago from air bag man in auzzie this is the qoute he sent me back it makes no sense to me i asked him to try make more sense of it as it looks to me like im paying for more than just the 4 bags i asked for. i can understand the brackets but it still seems over priced.
The kit quoted in the attachment is for a full "On Air kit", so replace coils with Air bags, and it looks like they have made a mess of the quote.
The Firestone Ride Rite kit for a GU/GQ will not suit coils, only leafs,
For Leaf sprung they are $799 del #RR4516 (same for std & 2")
Coil Sprung the only option with Firestone is "Coil Rite", inside the coil, rated to 200kg @ $299 del. # CR5042 for a 2" lift
We have another Australian supplier that supplies a kit to go beside the Coil spring in GQ/GU, It is a double bellows bag similar to the Firestone Ride Rite kit, They are $520 del. #LA15 (same for std & 2")
Hope it all helps.
It is messy,
The final price is about right for Front & Rear "On Air", bags and brackets.
If that's what you wanted I can re qoute it for you if you like.
Hope it helps.
BORDERTREK 4X4 & FABRICATION
Hello out there.
Thank You
I've sold and fitted a few Firestone Ride Rite kits they are very good quality and will work fine with a 2" lift. For rear leafs only too.
1 - 7 of 7 Posts
