I'll be mounting some roof mounted lights soon and wondered how people are routing the cables inside the car? I don't fancy drilling holes in the roof though.....any little tricks I should know about?
nissan patrol 1989 wagon
hoffy8
Hi Streaky
I read in 4wd mag that they are taking them through the Safari Snorkel. which they say is easy & does not affect the vehicle.
Hoffy8
I ran mine down the passenger side behind the snorkel easy as if you have a second battery to
Every dog has his day
2005 TD42 GU IV
An alternative if you have a full roof rack and maybe also have worklights at the rear is to run the wires down to underneath the car but on the outside of the door seal, no holes drilled except a few 5mm ones for riveting saddles, but you could use sticky pads to cable tie it too if you wanted to...
Not my doing this one but you get the gist...
of there is not to many wires ive seen them run from engine bay up the side of the windscreen under the windscreen rubber
Roof light wiring
Hi Guys,
I ran my wires down through the snorkel and out by the air filter through a sealed rubber grommet. A nice neat solution but only if you do it when you fit the snorkel! Stripping it out after it has been mastic sealed would be a pain.
Cheers, Rick
