1 - 16 of 16 Posts
If you drive a box you get box
alright, im sick of how fragile the stock flares are. ive got one of 4 of my flares that ISNT broken and rubbing / flapping against my panelwork
im looking into the rubber flare kits you see around the place. My next question, for those that have done it, is how much do you exactly need. I dont want to buy a 6m coil and find im just short
making them suit to factory mudflaps doesnt bother me, as ive gotten rid of them ages ago, so got generic rubber ones (that are half falling off too LOL)
for reference, these are the ones im lookin at:
NISSAN PATROL,NAVARA ETC RUBBER WHEEL ARCH FLARES (eBay item 290499234888 end time 22-Nov-10 15:38:06 AEDST) : Cars, Bikes, Boats
6m is spot on for a GQ but Go 7m for a little playing room. i used the bunings garden edging that was 6m in length and i had about an inch left.
Yeah i used the Bushranger flare rubber, a 3 metre roll was easily enough to do rear guards (with mudflaps fitted), so front's shouldn't be a problem as the guards are shorter.
cheers for the input guys, gives me something to do in the upcoming months
Matty lawn edging is where it's at!!!!! Ghetto
lol, this is one vehicle i wont be going ghetto on. i hate the standard garden edging ones when they sag
Anyone got pictures of a GU with rubber flares from Clark rubber or the like?
I used some 10mm rubber from clark rubber, cost me about $110 for 1.5 metres of it, then cut it lengthways into strips and it covered all 4 wheel arches, I made it really wide for the front so it covered right to the inner guard, that way it stops mud getting up into the inner guard section and in the front door hinge area.. The reason I didn't use bunnings garden edging was it wasn't wide enough to do the front properly, and the moulded rubber for flares is max of 75mm wide, but my flares stick out 120mm or more.. Here are some pictures:
Front inside before the aluminium
I also put some 1.6mm ally down the back for support, as the flares stick out 120mm + at the back of the front arch.
End Result
1 - 16 of 16 Posts
