1 - 12 of 12 Posts
I have a brand new crate motor td42t and im not sure which oil tu use to run it in. Ive also fitted up the oil cooler from the silver top and wonder which are the preffered choice of filter size and brand as I want the best start for the new motor. Cheers
Glasshouse Bogan #1
nissan patrol gu
Half fill the filters with oil before you fit them. Disconnect the fuel pump crank it untill the oil light is off then reconnect the pump.
Start it and give it heaps. Job done.
1 - 12 of 12 Posts
