1 - 2 of 2 Posts
Hi All,
Hope you’ve all had a good Christmas! 🙌🏾🥳
So I am looking in to running 35” muddies on my Zd30. I know I will have to change my diffs to the correct gearing but I wanted to know if anyone had any issues running 35” on a 3.0L??
I did read somewhere that it could lead to the engines popping (not on this site) and wanted to make sure this isn’t the case before I run 35s.
I would really appreciate any advice.
Thank you in advance 🤟🏾
Oli.
I have been running 35's for over 75k Kms and apart from the aftermarket upgrade suspension component bushes giving up quickly I have had no engine problems.
I initially went to 4.8 gearing from 4.3 as I was towing heaps and starting moving was a pain. After a few upgrades to the engine I went back to 4.3.
If you want to go back to standard gearing after fitting the tyres go to 4.6 if you have 4.3s. The 4.8s are a big jump. I'm not sure what revs a standard zd30 box will pull in 5th as mine has a TB45 box in it and 5th saw me at over 3k rpm at 110 when not towing.
Hope that helps, Andy.
1 - 2 of 2 Posts
