21 - 30 of 30 Posts
2004 Nissan Patrol GU Y61 ZD30 DI
Discussion Starter · #21 ·
thanks heaps mate I’ll switch them over tomorrow
Doing it now. There are two black wires with yellow trace though. One is thicker with two yellow stripes and the other is thinnner with single yellow stripe
correction: they both have two stripes.
is it thin or thicker one I connect to?
The one you need will more than likely be the smaller one. You will need to check to confirm. It needs to have power when the ignition switch is on.
The second one I think will only have power when you turn the key to start.
Awesome thanks heaps for your help
Discussion Starter · #22 ·
So it’s working as it should, it didn’t like the bigger black and yellow and ran something loud that sounded like a fan when I turned the ignition off. So connected to the smaller one and the timer is working perfectly. I do have the sub tank issue though
Y62
It's possible you have logged a fault with the sub tank module. Disconnect the battery for half an hour or so and see if that resets the subtask light.
Y62
The timer is running fine but the sub tank issue is still there. Trying to research some different solutions
So after you disconnected the battery and started the vehicle the sub tank light was out? But after the vehicle was shut down by the timer the sub tank light was on again next time you started the vehicle?
Discussion Starter · #28 ·
Yeah if I disconnect the battery it resets but comes on pretty soon after starting the car
Y62
That’s not the answer I was expecting.
There’s mods that can be done such as using a diode to power up the accessory circuit or changing the battery feed to the sub tank module to an ignition feed to make it do a reset every time the vehicle is started, but I don’t think these will help in your case, if the light is coming on while you are driving.
Try moving the shut down timers Blue wire from the Black wire with a Yellow trace and connect it to the Black wire with a White trace and see if that changes things. Disconnect the battery to reset the sub tank module again.
Discussion Starter · #30 ·
Thanks I’ll give that a go. I read up on some of the soloutions like a diode or a relay but couldn’t understand well enough to try.. my electronics vocabulary is basically plug, wire and that thing
21 - 30 of 30 Posts
