Hey guys I got a swb safari which lost power to accessories and fuel,oil,temp gauges and speedo not working...check fuses and they are all good so I'm lost as wat to look for next.
Safari Hoarder
ohooo that's bad. I was thinking your factory 24-12 converter might be out but indicators are not part of that. Look for a bad earth.
Lol I just discovered if I closed my passenger side door I get power for a moment.
Thats where the 12 volt converter lives (Lh A Pillar) assuming yours is a 24 volt model.
Its odd that you've lost power to accessories AND stuff powered via the IGN position. Has the car been fitted with an immobiliser? Favorite place to put the unit is under the LH side of the dash so I wonder if that is at fault and the vibration from closing the door is jiggling the connection.
