I have found a coolant leak between the block and the timing gear sandwich plate. Behind and below the alternator. Can't see exactly where because the thermostat housing is in the way.
Seen some scary posts saying, as well as all the timing gears and chain having to come off, the sump also has to come off and ,to make matters worse, the gear box has to be slid back, to remove the sump.
Does anyone know of a video or plan for removing this sandwich plate from the front of a zd30ddti. Or, a really good high quality leak sealer for a cooling system. Thanks
