im just wondering where abouts is the best place to mount this scangauge
IMHO not to bad at all out of the box... the suppliers are extremely helpful if you have any hassles or post up here.thanks for that guys, im hoping its a user friendly device
The only issue I found with mine is that the Scangauge measures boost pressure as an absolute value via the Map sensor so was registering normal air pressure of 14.7 ish then adding the boost pressure on top of that figure. I did find a pdf file however that found a way around it and it now measures boost pressure starting from 0.thanks for that guys, im hoping its a user friendly device
Not sure... Having worked in aviation for a time I run mine as MAP as I haven't bothered with the X Gauge Boost thing so one of the others will help you there hopefully...i did the bst gauge thing and at idle its shows -05 is that right. but i must say a great bit of gear. is there a code for oil pressure
