1 - 20 of 64 Posts
· Senior Member
Gday Guys,
I figured it was about time i put a members thread up in here for my GQ.
Ive had the shorty for about a year and a half now and its been a great truck in the time ive had it.
Current specs to date include:
- TD42 with aftermarket turbo
- Large front mount intercooler and boost controller ( setup is running 15 pound boost )
- GU ZD30 intake
- AU twin thermofans
- straight through 3 inch exhaust
- snorkel
- duel batteries
- cheezy bullbar and rear bar / carrier
- Custom made sliders
- 8000pound low mount winch
- 5 inch coils, 2 inch bodylift ( all tough dog and snake aftermarket uppers and lowers )
- aftermarket snake steering arms, diff guard.
- rear coil retainers and guides
- double cardin rear shaft
- 35 inch MTZs for the road and borrowed 37inch creepies offroad
- ARB airlockers front and rear running aftermarket 4.625 diff ratios
- Aircompressor
- rear quarter chop
- Interior rear 4x4 drawers full length
- 6 speaker, sub, 2 amps for some quality listening
- Mechanical oil pressure and water temp guages, boost and EGT guages
- spotties
- YURI 4x4 Strengthened CVs
bunch load of other custom bits and pieces i cant think of off the top of my head....
anyways this is how i bought it...........
No lockers or gears etc lift was already in it along with some of the other goodies.....
· Senior Member
had to remove the 2.5 tonne eyelets that were on the bullbar and rear bar and replace them with something stronger as CCDA wouldnt pass eyelets as recovery points.....
I unbolted the eyelets, cut them out and welded new peices of 25mm thick plate in through the bar welded to both sides....
· Senior Member
Discussion Starter · #19 ·
The intercooler pipework was a little tricky.
I wanted it out of the way.
I ran it through the front fire wall and behind the headlights and out and inbetween the outer and inner gaurds on both sides and back into the engine.......
I lost a 2 pound pressure drop from 12 pound to 10 pound when i did this, i then fitted the boost controller and wound up the fuel. I now have 15 pound and no noticable difference in lag.
1 - 20 of 64 Posts
