1 - 2 of 2 Posts
Hi.
Cylinder head between valves are a bit cracked on all cylinders. I have heard different opinions, that its fine, happens to all diesels and runs fine. Im not quite sure. Looking for opinions.
Automotive design Automotive tire Audio equipment Rim Automotive exterior
1986 SD33T SWB
You will need to get it pressure tested by an engine builder.
Cracks between valves are very common on SD heads, but it's impossible to tell visually how bad the cracks are.
1 - 2 of 2 Posts
