1 - 14 of 14 Posts
1986 SD33T SWB
Simplest, easiest and cheapest option is a factory turbo setup.
Landy hasn't been around here for a long time.
If your engine doesn't have the upgraded internals and injector pump of the SD33T then that will limit what you can do with your engine anyway.
Reactions: bent
Yeah bummer he’s not around thanks for replying though awesome. my one is standard sd33 but was willing to do whatever is needed depending on the cost. Would you know anyone that has factory turbo for this I’ve been trying but obviously in the wrong places
Pass the Popcorn
Nissan Datsun Patrol
Where are you located Milkman.
I have everything you might need for a ht18 turbo install including 3" beaudesert dump pipe, oil return drain and cast elbow off the impeller wheel and factory pipes with the airbox lid.
Happy to work something out if you decide to go that route.
Hey there MQTray, have you still got the turbo set-up? I am in SA near the Vic border. Cheers Lana
Pass the Popcorn
Hi Lana,
Yeah it’s still available. I’m located in eastern suburbs Melbourne.
2016 CRD wagon
Well this is a timely and coincidental thread dig 🙂
@MQTray @shantillylais
If @shantillylais doesnt take the turbo setup, I may be interested......
My young fellow is building a MK with a SD33T and we have some issues with the turbo (and maybe the injector pump).
Is there much to upgrading from the std turbo (I dont even know what it's called) to the ht18?
I'll read through the thread linked above anyway.
Reactions: Marko_SJ
Pass the Popcorn
Hahaha @trev zd30 When it rains it pours.
I’ve read Ethan’s thread and wish him all the best with everything he’s dealing with to get it back on the road. The education along the way will be invaluable.
Absobloodylutely
1 - 14 of 14 Posts
