1 - 3 of 3 Posts
Hi all I'm at a point where I am installing my piston sleeves. I have a sd33 engine manual (I can't find a sd33t manual or supplement anywhere so if you can help with that it would be amazing as well) so assuming the liner protrusion is the same I'll be mint. But the question I have which I can seem to find the answer to is do I use a retaining compound on for the cylinder liners? The book doesn't mention it so at this point I'm assuming not. If anyone has any more insight I would be very thankful.
1986 SD33T SWB
Cheers mate. The link doesn't work unfortunately. I just got my new liners today. I'm an yet to mic them but all my bores measured up as per specs. Once I measure up the liners I'll be able to see if it will be a nice interference fit or not. So long as all the numbers are the same between the 33 and the 33t.
1 - 3 of 3 Posts
