1 - 9 of 9 Posts
The plug on my temperature sensor keeps falling off, its the one with two wires that attaches to the sensor on the thermostat housing.
Any body know where I could get a new plug?
I rang nissan and they gave me some spiel about having to replace the whole engine bay wiring loom...
just after the plug, sensor itself works fine...
Quickest Tyre Deflator On The Market
Yeah, That'd be right!!!:angryfir: you should be able to pick one up at a wreckers.
Whole wiring loom indeed, what a load of old codswollop.:D
I might have a spare you can have, will check when I get home... Are they all 12v or will you need 24v???
Problem solved
Thanks again Marc!
does anyone know where to get the temp sender from. i 've tried a couple form bursons but the 2 they have give me have been the wrong ones
1 - 9 of 9 Posts
