1 - 5 of 5 Posts
2016 CRD wagon
Hi MQ/MK gurus
Can someone tell me what the sensors pictured below are for and how they work (if known)?
These are all at the front of the motor.
Automotive tire Motor vehicle Gas Plumbing Rim
And
Motor vehicle Automotive fuel system Automotive tire Gas Auto part
Both have 2 wires. The top one goes into the thermostat housing...... but there is already a separate temp guage sendor just near it.
I'm wondering if the second is a tacho signal??
TIA
Reactions: Scout2mike
1986 SD33T SWB
The sender on the front timing cover is the tacho sender - its a magnetic pickup or hall affect sensor from memory.
I'd guess the best way to test it would be with a multimeter on ohms and spin the engine over, or remove it and pass some metal close to the front of it. Use a thick gasket when you reinstall or reuse the old gasket if its okay, it needs that thickness to set the depth of the sender to the timing gear.
The sensor of the thermostat housing is coolant temp for the glow plug controller. It is supposed to let the plugs glow longer with a cold engine, and turn them off quicker with a warm engine.
Nissan's electrical documentation in the 80s was patchy at best, so they don't really give much in the way of what sensors and senders should produce what values.
Reactions: trev zd30
2016 CRD wagon
Thanks James. Very much appreciated!
I plan on a simple momentary switch to operated glow plugs for now so no worries about that coolant sensor.
With regard to tacho, do you know how the L28 sensed rpm? Did they use a similar system or was it sensed from the distributor or other ignition components?
I've had a look through the wiring schemes you linked in a different post. One thing I'm having trouble is identifying colours for wiring which would make life just a bit easier. Any hints or is that info difficult to come by?
2016 CRD wagon
@james008
You've got me curious now.........
If the sensor is on the front of the sd33t for the tacho, where is the tacho pickup on a NA sd33?
1986 SD33T SWB
No worries mate.
A momentary button is simple way of doing it, IH Scouts used them from the factory, and a pull cable as an engine shut off on SD powered Scouts.
It may be worth looking into a 555 timer or timer relay if you or the young bloke were so inclined.
From memory the L28 tacho pickup was in the dizzy or triggered from the coil.
There should be this little table at the bottom RHS of the last image of the wiring diagram that shows colours and connectors.
534619
@james008
Early SD33s didn't have tachos or the boss in the timing cover. They got them a bit later on with other MKs though in the same spot.
There is another very similar looking boss on the timing cover but just behind the harmonic balancer. No idea what its for, some marine or commercial application probably.
1 - 5 of 5 Posts
