1 - 9 of 9 Posts
Seat mounts cracking
Hi Everyone,
Had a quick search and did not find any info, so I will ask away!
Nissan GQ 1989 model. Rear inside mounts on both Drivers and Passengers Seats have cracked/torn through.
Just wondering if anyone has fixed this issue. Apparently it is not common but I have owned two GQ's now and both of them were knackered! haha Guess I am just lucky! (Did not fix the old one)
So just wondering how what would be the best fix of someone has come across this...
I will post up some pics...
Driver side pic too large to post up but it is the same.. maybe a little worse as I am a fat bastard! haha
GU IV 4.2
Same problem on my drivers seat, rear inside mount. Its pulled the threaded section right out of the floor so seat is not attached to floor there any more. Need to get around to welding it back in, probably the easiest way to do it i would think?
i i remember correctly. there is a bracket bolted to the floor under the carpet there.
all the earlier ones were of pretty poor design and not braced at all. the later ones were gusseted and reinforced to make them stronger. both mine were cracked when i had the carpet out so i just got some later model ones and happy days.
so go pull the carpet up if you can and have a look. pretty sure im right.
nissan/swb gq
so go pull the carpet up if you can and have a look. pretty sure im right.[/
Yep your right
I just replaced the passeger side in my SWB . it just unbolt's
pretty esay job to repair . or just gat one from the wreckers
nissan patrol gq
seat mounts
hey guys my seatmounts are cracked but it is the middle row seats its fatiqdue
do u know anything about that
nissan patrol gq
yea mate that looks like them heres a few pics of mine
1 - 9 of 9 Posts
