1 - 2 of 2 Posts
my ute is a mk 3.3 na and has a new 3" efs lift in it.. its like the springs are too short or something the front right sits a tiny little bit past verticle (spring end towards the front ) but the left is a little bit the opposite how do i get the shacklse to be even and at the rightangle.. the rear is verticle (no tray or weight) ( never been offroad yet)
nissan mk
Have similar problems, loosen off the nut on the shackle and jump up and down on the front, shackle should rotate. The poly bushes only need about 30ft/lbs or they bind up. They both should hang forward a bit.
1 - 2 of 2 Posts
