After some help with understanding the difference between a single and twin cylinder compressors.
The two I am comparing are the XTM from BCF/SCA and the Projecta Typhoon from Anaconda.
Their current draws, duty cycles and max psi are the same and the XTM puts out 160LPM vs 150 for the Typhoon. The only unknown variable is the cylinder diameter. The XTM one is 60mm, however the typhoon does not give specs on this.
Now my understanding is that because the flow rates are nearly the same they will displace a similar volume of air per min. This would mean that the single cylinder compressor would have to work twice as hard to displace roughly the same volume of air per min. If this is the case then it would naturally run hotter, hence affecting its duty cycle. They have the same duty cycle however.
These are the compressors in question:
P.S. don’t even get me started on the Ridge Ryder vs XTM single compressors. Exactly the same specs, even look the same, yet $99 vs $275. Go figure.
