1 - 10 of 10 Posts
Hi,
I have been looking for a set of front slotted rotors for my 1993 DA Maverick. Been having HEAPS of trouble sourcing one. Was just wondering if someone could reccommend a company to source from, or any alternatives.
nissan patrol gu 4.2 td
Hi,
Any good brake shop should be able to slot a set for you
or upgrade to a set like mine
(check my garage)
nissan patrol gr
interesting post, hard to find the rigth part rotor my y60 92 carby, because dba shows 2 kind of these
If i choose for "1987 on; gq y60 all" they show me those DBA4622SL and DBA4622SRm they are 315x18
If i choose for "1987 on gq y60 non EFI", they show me DBA329SL and DBA329SR, they are 294 x 20
Then mine is patrol y60 short, carby from 1992 so wich sould to get?:confused:
DBA Rotors
Had a set of slotted rotors fitted recently.
Would you believe they are available thru Ni$$an dealers.....
Cheaper than the local brake place by $50 per corner..
Maybe nizzbits can do a deal also??
Secret is in the rotor diameter.
Pull a front wheel off and measure the rotor diameter.
Also I believe that 15" wheels won't fit over the larger diameter brakes.
nissan patrol gr
I have 15"s so they have to be the shorter,(smart advice thanks) tomorrow i will pull of the wheel because i dont have brakes, strange sound under left wheel and large brakes.
Banned
You want the 329's. I am pretty sure the 4622 is for the injected petrol with the twin piston caliper. I just fitted a set of 329's to mine which is a mid 92 diesel.
Ben
the 329 is the most common disc fitted the other is for the efi fitted with twin piston caliers i have not found many with them on so far (thats in 10yrs)
also how much are your brake guys charging as some local nissan gets the discs from me
1 - 10 of 10 Posts
