There's a few threads on sound deadening around here.Anyone used pingjing or any of the ebay sound deadening, or am I better off just pay for carbuilders.
Is the mass noise liner lite better then juwt the acoustic foam for the floor too?
Do you remember where you got the mass noise liner from,which wholesaler?There's a few threads on sound deadening around here.
Myself, I used PingJing damper, it seemed as good as the more expensive options and took the ringing noise out of the GQ bodywork.
Then, I used Carbuilders foam throughout, with overlapped layers of MLV on top of that. I got the MLV from a wholesaler.
I used a sheet of Carbuilders heavy noise liner (MLV + Foam) in the rear cargo area.
Really, mass noise liner (MLV) is needed as a barrier on top of the foam, which acts as an isolator.
Carbuilders are great to deal with, they have good products and good advice, so if you were to get all your acoustic products from them you'd probably do ok quality-wise rather than shopping around piecemeal like I did.
I went through all this recently. I basically ended up with the top pack from carbuilders minus their stage 1 sound deadener. I'll use pingjing instead which works out significantly cheaper.
I got the carbuilders stuff at something like 30% off on their black friday sale, but theres also a constant 10% discount if you sign up to their newsletter I think.
4x4 Wagon Packs - Sound Deaden Your 4wd with Premium Products
Your 4x4 touring wagon should be a source of exploring pleasure, not annoying noises. Fix the problem quickly and efficiently with our wagon packs, including enough insulation materials to cover your cabin's interior.www.carbuilders.com.au
Pingjing I haven't gotten yet but will grab from here
PingJing 30 sq ft butyl rubber sound deadener
BUTYL RUBBER SOUND DEADENING is used to reduce panel vibration which will reduce road noise, improve sound quality from your audio system and moresoutheastcaraudio.com.au
When I next have time off work I'll get it all done. Until then I have a small army of boxes from carbuilders in my garage :|
I got my MLV from here:Do you remember where you got the mass noise liner from,which wholesaler?
