Hi guys,
Hope you can help me out here, regarding the Stabi Disconnect circuit on a 2007 CRD GU.
I have done a suspension lift and removed the factory stabi disconnect and need to locate the correct fuse to cut the power to the circuit as the "Stabi Disconnect" lamp is perminately on.
Have looked at the fuse panels under the drivers side dash and under the bonnet but can't find a fuse marked for this function. The handbook is of course useless!
Anyone got the info?
Thanks, Rick
Discussion Starter · #2 ·
Stabi Disconnect Fuse
No one any info for me?
Tried various searches here and on Google for a list of fuses but no luck.
Advice anyone ??
Cheers, Rick
if its like the gq i think i just cut the wires underneath that come out of the unit. I havnt seen a fuse or relay for it at all.
Stabi wiring
Thanks Dazz, but there is a connector about 6" from the control box bolted to the chassis rail which I disconnected.
The stabi control unit is still powered-up and gives a stabi warning light on the dash permanently. The control unit is buried deep in the dash behind the center console and not easy to access.
Anyone else have ideas?
Thanks, Rick
