Hi, I have a 2005 Y61 (facelifted, UK spec). This is my first Patrol having finally given up with Land Rovers.
I have noticed that the Stabi light flickers on and sometimes glows on whilst driving on road. It does go off of its own accord eventually.
Stopping and switching the stabiliser off then on seems to temporarily help, but the symptoms return.
Can anyone suggest what may be causing this?
Nissan patrol y61
Watching with intent as I have this issue. Have found mine is from wet weather and is permanently on at the moment. The control box is nearside chassis rail just in front of the rear wheel, you'll see a cable running from the piston on the anti roll bar back to the control box.
Nissan patrol y61
Small update, after 6 months of being on, hit a pot hole yesterday and it's gone off now. Time to see if it actually works properly or not I think.
BORDERTREK 4X4 & FABRICATION
The contact switch is inside the plastic cover on the disconnect. It could be loose or the wire is broken. When makes contact it closes the circuit and lights up on the dash.
