1 - 2 of 2 Posts
Hey guys,
Im in the process of wiring up a Viper 3105 (350 Plus) alarm, immobiliser to my 1995 GQ ST. I have everything working fine apart from the starter kill relay. Can anyone confirm for me the colour of the starter wire?
I believe it is the black and yellow one, so I have cut that and connected the ignition side to pin 87a and the starter motor side to pin 30. For some reason, even when armed the car still starts. I am pretty certain i have the right wire because when i first cut the black and yellow wire i sttempted to start the car and it wouldn't crank.
Any ideas on why this would be happening? Has anyone wired up an alarm in their car than can shed any light on the issue?
Cheers,
Col
GHMBC #3
nissan patrol gq lwb,3"lift.
30 to power from wire you cut(power).86 to trigger/alarm (so when alarm is off it allows power through when turning key)87 to starter relay 85 to earth.87a (5 pin relay)is same as 87 just usually halves/shares amps with 87
1 - 2 of 2 Posts
