I've done some searching but haven't yet found anything that relates to my problem.
Nissan Safari 24v, Alternator light comes on at ignition and goes off after starting.
Gauge indicates 27-28 volts under revs.
Batteries with eng not running are (Passenger side 12v) = 12.95
(Drivers side) 24v = 10.88
I replaced the drivers side battery last week so it was at 12.7v then and has obviously lost charge OR is not being charged properly despite the gauge reading normal etc.
I had starting probs prior to that hence putting the new battery in. The engine is now only just turning over again. I'm about to go out and check all earth and alternator connections, I know that the battery terminal connections are good. I 've got 24/12 volt reducers running off the 24v side battery...all done by an auto sparky and they've been that way for 3yrs now with no problems.
How do I check my alternator output voltage?
Any other ideas welcomed.
Jamie
Jamie
