Good evening all and thanks for all the information I have already used on this forum.
I have recently purchased a 2000 ZD30Di with a limp issue at cruising speed.
The following was done by previous owner through mechanics to try and fix the problem.
:New MAF
aws valve
:General service
:Check EGR, TPS
I have replaced the new MAF with a genuine one.
Looked for leaking vac or intercooler but seems ok.
Today I finally got the boost gauge on it and was expecting some sort of over boost problem
but instead got the following.
Seems somewhat normal until you put a fair bit of acceleration on it then it will drop from 14psi to 7psi
At cruising speed it will be at 14-15psi and sometimes limp (Lift accelerator and it will return power) .
At cruising speed if you put foot down it will drop boost from 14psi down to 5-6psi and take ages to build boost.
Seems that boost is high and drops massively when asked for power.
Most of the issues are above 2500 revs.
What next ladies and gentleman?
Any help or advice would be much appreciated.
:New MAF
:General service
:Check EGR, TPS
