1 - 3 of 3 Posts
NISSAN GU PATROL
Hi Guys
I have the TB45 on LPG and a 75litre sub fuel tank is used as the main tank.
My question is if i remove the carpet is there acces to the fuel pump/sender from the floor, or do i need to remove the tank?
Reason is i want to adjust the sender as when the tank is full the fuel guage dont show that its full and i seem to run out of fuel before the fuel light on the guage comes on, so i fugured i could just do a bit of bending/adjustment of the sender.
Yes remove the carpet and the inspection plate is underneath. You will find it more accessable if you remove the drivers side middle seat as it allows the carpet to move a little futher and make the process a little easier. My previous Patrol was an auto 4500 on LPG to.
David.
NISSAN GU PATROL
David.
Thanks David
1 - 3 of 3 Posts
