Im installing a long range tank ( sub tank replacement ). Im wanting to know what controls when the transfer pump turns off. Does the fuel sender send a signal when its empty to turn off, or does the pump have a sensor that detects that no fuel is flowing??
Cause if its the fuel sender I'll make sure it swings down as far as it can. And what the f### is that plastic cylinder in the bottom of the tank for?, its not connected to anything!
Also does anybody know how the roll over valve work?
