high there to every one i have a 2 inch lift already with coil spacers and have bought a 4 inch lift to go into my gq wagon now the question is if i install the 4 inch lift can i use the spacers as well and would that give me a 5 inch lift in total
of course you can, but there are other bits and pieces you need before even your 4" lift will work properly. Longer brake line, brake bias bracket, adjustable panhard, castor correction.... You may need bumpstop extention, pinion angle correction...
i just had the casters done what will it involve with a correction and i have brake lines on the way but didnt know about the bias correction bracket what is this and i will need both front and back pan hard rods is that correct
All the stuff you need, might need and might want and why, including a picture of where the brake bias bracket goes ($25) is written within the above link.
You will need front and rear panahard rods and upper adjustable trailing arms if you have a wagon or longer lower trailing arms if you have a Ute. (Tyre and guard clearance reasons)
Take note when it talks about bump stops. It isn't a matter of if you need them it is a matter of how high.
