1 - 7 of 7 Posts
Hi All,
I have a 07 coil GU ute with 50mm OME lift. Does anyone know where I can get sway bar repair kits front/rear to suit. I can find on the web some suppliers that sell bushes and some that sell links but none as a complete kit.
Thanks, Kevin
Rogue
nissan gu patrol
I cannot say I've ever seen someone retail a sway bar repair kit before (just links and bushings), generally these are two different items as lengthened pins for lifts vary a lot, so there is no real standard link bushing.
As mentioned, just give Road Runner a call, they're very good to deal with.
Front bushes, you need two.
http://www.roadrunneroffroad.com.au...ff-end-GQ-Patrol-GU-Y60-Y61-Kelpro-22366.html
Rear bushes, you need two.
http://www.roadrunneroffroad.com.au/Sway-Bar-bush-Rubber---Rear-Nissan-Patrol-GQ-GU-Maverick.html
Extended links (should suit your lift fine)
Nissan Patrol GQ Front & Rear Heavy Duty extended sway bar link kit - www.roadrunneroffroad.com.au
Call them and ask for a Mudrhino/Patrol4x4 discount
Who cares if they are in a kit? They'll post it all together in the same transaction.
Thanks all for your replies. Have contacted RoadRunner
Kevin
+2 vote for Road Runner. Replaced all the bits on my sway bars and got them all from Road Runner. Good as gold now.
1 - 7 of 7 Posts
