1 - 3 of 3 Posts
Those ones that fill the places where switches are supposed to be in the center console...do they just come out with a small screw driver to pry them out? Buggered if I can get mine to shift :-(
I don't want to scratch or break anything....do they simply pop out that easily?
They come out using a screwdriver.
Each side of the square has a stiff tab that locks it in. Look at the switch or rj45 mechanism you are about to snap in. It holds in the same way. Don't worry about breaking the insert. Try not to mangle the plate too much though.
Yes they just pop out, there is a lug on both ends that clip into the panel, there is a slight offset on diagonal corners so you are better off levering from the centre of the top or bottom, gentle leverage with a very thin blade screw driver does it for me.
1 - 3 of 3 Posts
