Nissan Patrol
Hi Guys,
While flooded under water my dash was going nuts and the tacho was spinning round back and forth and has now stopped on the wrong side of the needle. Anyone had this problem or know how I could fix it?
Thanks.
Pass the Popcorn
Nissan Datsun Patrol
Water got into the ECU. It's ****ed and you need a new one!
There are other threads on this, just recently infact.
Nissan Patrol
ECU is fine and tacho would be working fine as well if I could get the arm back to 0 on the right side of the needle. Does anyone know if this can be done without having to pull the whole dash apart?
nissan patrol gq
I have heard of it before (maybe not on a patrol). Leave the car in neutral (or park if auto) and bring the revs up close to the limiter (not more than a second or two). The needle should reset and follow the revs down.
Cheers,
Nic
Sent from my iPad using Tapatalk HD
yeah I had to fix this on the FIL's Di zd30, revved it to like 3grand for a few seconds or somthing like that and it flipped back, Never done it since.
Cheers,
Nic
This fix worked a treat cheers.
