Hey guys, been clocking up quite a few km lately and on my last big drive tacho decided to start doing random crap 25 hrs into my 28 hr drive.
I'm running a Dakota digital as it's a ZD to TD conversion. Checked today on the Dakota what RPM the dash would show using the built in test function (meant to send a 2000 RPM signal to cluster) and it was spot on.
Picked up a new multimeter today that can measure frequency and tomorrow I'll take some measurements at whatever connections I can find between the tacho sensor and Dakota to see what PPM I get (there's a thread Ive saved where someone has done the same so I have some rough figures to expect). I have the tacho sensor near the thermostat housing FYI.
Is there anything else I can look at to try and diagnose what the problem is? I need to pull the cluster out to replace a flickering led, which started happening on the trip prior up on the cape, thought they might be related issues but the Dakota sending the 2k RPM signal successfuly seems to indicate otherwise, but maybe there's something I can look at there as well?
TIA
TIA
