My rear tail shaft is out of phase, it looks like I should be able to:
Unbolt the short end (narrow)
Pull back the rubber boot on the slip joint
Remove the retaining nut (I guess it’s threaded)
Pull the shaft completely out of the spline
Square then ends so they mirror each other
Reinsert shaft into spline
Put back together.
Is this the correct steps I should follow for my LWB GQ?
Put back together.
