nissan patrol gq
hey guys my tailshaft nnipple snapped of yesterday and was wandering if you can replace them cheers:confused:
sure can replace them if you havent got the thread out of the hole you need to get it out before you can fit a new one. Easy Outs are the best way to get it out but wouldnt expect you to go buy a set just for one use. try a pair of long nose pliers or a flat blade screw driver to get it out then u just need to get ya self a new nipple. Should be able to get one from a auto shop the broken off threaded bit u can probally use as a sample size to show them
Quickest Tyre Deflator On The Market
Some you can, some you can't, try a small ezyout but make sure you take the tiny spring out first, as you may push it into the joint, if it was a hexagonal nipple, it should screw out.;)
nissan patrol gq
nipple snapped of tailshaft
ok will try and see if there is a spring and get it out then will try pliers and screwdriver before i go buy a easy out
thanks guys much apreciated:cool:
