1 - 5 of 5 Posts
Im in the process of doing a tb to td conversion. I bought a td fan hub and I have found that my standard TB fan is is far to big for the hub. im wondering can I use the whole TB fan and hub assembly on my new TD more?
will it have any bad effects on cooling or anything like that ?
ok, so can I use my TB clutch fan and hub on my TD, will it cause any problems ?
Every dog has his day
2005 TD42 GU IV
As long as you use the clutch AND fan together it will fit fine. I have a petrol fan and clutch on my TD42 and it has no problems. It doesn't seem to work any better or worse from a cooling point of view.
1 - 5 of 5 Posts
