1 - 9 of 9 Posts
I need to do the front main seal on my bus,
i was just wandering wats involved in doing it or should i pay a shop to do it?
i am fairly mechanically minded
you basically just need to remove all the belts. remove the harmonic balancer pulley and then just swap the seal out.
but you will most likely need a harmonic balancer puller to be able to get the pulley off and you need to remove the rad to do this.
they arnt that hard to do. long as the seal goes back in right and the harmonic balancer isnt to grooved you should be sweet.
1 - 9 of 9 Posts
