Hello again, just pulled my head off the gq. After it forever getting hot and using water about 1ltr to top up radiator after having the rad fixed about a month ago, ive replaced the clutch fan with two thermos off a au ford it now has a total of four fans , still got hot after running down the road to the shops etc, so ive pulled off the head and found no 6 cylinder full of water and the spark plug a bit water logged etc the head gasket looked shagged at the back of cylinder head , has anyone else come across this is it common , should i check the push rod of piston to see if goes to the top of block evenly
cant be good trying to compress water go to get the head checked out and tested etc
then she should be on the road .
has any stayed at gordon country camp grounds near beauderest going there for easter holidays cheers simo
