Basically I have had issues with getting my GQ to start since I bought it. The issue is occasionally it won't even attempt to turn over. It just sits there and does nothing. I can hear the solenoid kicking in but nothing happens.
To start with I replaced the starter, this fixed the problem for a while then it came back again. I assumed it was a dead battery so I had it load tested (it failed) and I replaced it. This fixed the problem for a while but recently it started doing it again.
I got stuck, away from home, and it wouldn't start, I checked the battery and it was at 12.2v so a little low, but it should still try to turn over. I gave it a little tap with a hammer and it started up fine. Checked the voltage and it was sitting at 13.3 at idle, so I don't think its the alternator, I'll need to test it with everything running to be sure though.
I ripped the starter off and took it back to the auto elec I bought it off, but he's yet to get back to me.
But the thing I'm expecting him to tell me its ok and to try and dodge out on replacing it. What I want to know is there anything else that could cause the car not to start until I tapped the starter. I've been told a damaged ring gear could cause it, and I do occasionally get grinding sounds when I try to crank it. But from what I understand a damaged ring gear would cause the starter not to mesh correctly, not stall it.
I'm at my wits end with it, and I'm starting a new job where I need to drive 200km a day so I want the damn thing reliable, at the moment I can never trust the bloody thing.
