1 - 8 of 8 Posts
Hi guys,
I going to make a EFI to carb conversion to my TB42E project as is going to be use only for off road, water, mud.
What exaclty do I need - intake manifold is a direct swap to EFI or do I need to adapt ?
thank you
GHMBC #3
nissan patrol gq lwb,3"lift.
carby,manifold,dissy,petronix 2 if you want to use yr existing transformer coil,remove crank angle sensor (do they have them),throttle cable is the same-just slightly longer on efi,fuel pump,carby has mechanical pump. i have a manifold and carby thats done less than 100k,would swap for yr efi manifold.would probably have the carby throttle cable as well and maybe a dissy less cap with a ground collar ready for a petronix 2 non lobe sensing would probably have a mechanical fuel pump if i looked hard enough
block and head are the same,just yr electrics,fuel system and ecu are different,and no maf or O2 sensor needed
Ok, so I need the carby, manifold and manual pump.
But why I can not use the existing distributor? Is not linked with the carby?
Thanks
the std tb42e dissy is locked and the ecu handles the advance/retard of timing, you need a dissy with mech/vac advance if you go back to carby
nissan/1989 gq
Just sell the efi and buy carby one. You will even make money out of it. efi patrols are more expensive as they are heaps better.
Sent from my SM-G900I using Tapatalk
nissan/patrol
Are you doing the conversion solely because you want to drive in mud? To me it a backwards step. I'd be spending time on waterproofing all your electrical gear with water dispursant, silicone and liquid electrical tape on the back of the connectors then coat them once plugged in. Also the carby air filter assembly is hard to make waterproof unless you spend big on a metal filter housing.
1 - 8 of 8 Posts
