1 - 5 of 5 Posts
Hey fellas,
how the hell do you get that MIDDLE spark plug out? What tools do you use?
I got No 6 out easy enough, using tips from here. So I thought the worst was over. D'oh!!
Even taking the throttle body off looks like a SOB!
Mark
nissan rx
The appropriate spark plug spanner - Can't remember which one but I have one of those "wobbly multi joint" ones or a socket one with "wobble" extensions and I also took off the rocket cover once.
Using the correct pspark plug spanner and taking time works
Nissan Safari
I took all the airhoses off to the throttle body. Moved throttle body wires out of way. Normal sparkplug socket with uni joint fitted well. I also had to move some hoses out of the way to get more turn on the socket handle. I thought plug six was worse as the turn area was smaller and had to reach right back in motor. I found sitting in the engine bay to do plug three also helped.
Reactions: no eye deer
Awesome!! thanks fellas! I'll go to it again !!This time,I'll pull the intake ducting off!
Thanks!!!
1 - 5 of 5 Posts
