Hi guys! New to the Forum but looking forward to meting you all!
Unfortunately my first post has to be because I Have a problem! hopefully you guys can help me out
First details of the car
Its a 1989 GQ SWB 4.2 TB42S (carby) Running dual fuel
Gas system is Impco with a 300A Mixer
Anyway the problem is a little long but i will try to explain it clearly
Originally the car needed a general tune up when i bought it, as it was running a little rough, took me a while to get around to this but it has been done!
The problem I am having now is that whenever I am driving, it has a seemingly random misfire! As it misfires the Tacho meter fluctuates, the needle quickly drops and returns as if the power is being cut and turned back on very quickly. this causes a back fire sometimes and makes it quite hard to drive. It can happen when the engine is hot or cold, under load/no load but seems the worst when I am coasting like slowing down for an intersection, that's when it flicks constantly!
This problem happens on both Gas and Petrol but i am just trying to get it right on petrol first!
SO... I have replaced
The spark plugs (NGK BP5ES)
Plug Leads (Champion LPG Compatible)
Dizzy Cap (Bosch)
Rotor button - extended type
Points
Coil (Bosch)
And Set the point gap
Set dwell to approx 36 degrees
Timing to Approx 12 degrees
Checked the ballast resistor operation (12V on cranking 9V running)
Adjusted Tappets to .381
Also fitted brand new professionally fully reconditioned Genuine Carby
It has a great IDLE and feels good throughout the rev range except for this random miss
Have even had it on the old computer diagnostic machine at work that does a power balance etc and can't spot the problem
Me and the guys are out of ideas and I am hoping someone out the knows whats going on!
Was thinking of getting a Pertronix Ignitor but I am worried the problem is elsewhere and was hoping to diagnose the problem before chucking more parts at it hoping to fix it
Please help and look forward to hearing from you all!
Rob
Dizzy Cap (Bosch)
Points
Coil (Bosch)
Rob
