Hey guys,
I've got a dual fuel LWB Maverick, which started doing the usual "stall on coasting" thing after I installed a snorkel.
I played around a bit, turned the snorkel head etc and eventually installed a balance line going from the airbox back to the converter.
Now, after doing this it ran beautifully on gas, no stalling, no problems, but then suddenly, the motor began to bog down under acceleration. Will not rev past about 3.5k, at first I thought it was just out of gas but I refilled and thats definitely not the problem.
If I hold it on a steady throttle it seems to be okay, but if i put my foot down, stutters, bogs.
I tried fiddling witht the screws on the converter, but decided that since I haven't got a clue what I'm doing with LPG that I should leave well enough alone.
Will be going over it this weekend with a fine tooth comb but I was just wondering if any of you have had an issue that sounds similar?
It still runs fine on petrol, if a little thirstier than normal.
Some pics:
Balance hose from airbox back to converter:
Mixture screws/converter:
Some pics:
