1 - 18 of 18 Posts
nissan patrol gu ti
hi guys just wondering what sort of fuel consumption you are getting from your4.5 mine i think is pretty bad but i have a supercharger on.
out of both tanks about $180 worth of fuel i get about 350-400k's is this half normal.
also how do the 3lt's go on fuel i am thinkin of buyin one for the missus so it's a bit cheaper for her to drive to work because she still wants a patrol.
Round town i get about 20l per 100 and on the highway been down to 16l per 100. Supercharger on a 4.5... Mmmmmm do you have any pics or details to share.
NISSAN GU PATROL
I get about 350 to 400 ks out of my 70lt sub tank, and about the same out of my 90lt LPG tank.
If your getting 350-400k's out of both tanks in total, thats way over, theres obviously something wrong.
nissan patrol gu ti
i would have thought the supercharger shouldn't change it at all if anything should make fuel consumption better if drive normally.
doesn't the charger just boost inlet pressure it shouldn't have anything to do with fuel rates directly, i thought that would be left up to the cpu.
That is kind of correct, superchargers use crank energy to make extra power and there for not realy all that effiecent compare to turbo's. Turbo uses exaust gases to turn turbine which compresses air and sends it into intake and then engine combustion occurs and this whole process reoccurs.
This is just a quick explanation of what happens and what is better for fuel consumption.
i get roughly 380 - 400lm to a main tank and thats running 35's and a 4 inch. plus the patrol is over 3t in weight.
A45 AMG, Ranger :(
My old patrol with the 35"s and 4.6 diff's i got 380-400kms on the main tank, total of around 600k range.
What supercharger are you using?, positive displacement or centrifugal, what management, if it is some piggybacked ecu on your standard nissan ecu it wont be flash. You cant expect good economy from an engine you are trying to extract more horsepower from, especially a TB.
A45 AMG, Ranger :(
There is no reason it would use more fuel when cruising though, when using the power obviously.
Piggybacked ECU's can work well if setup properly.
Id be checking and cleaning AFM, checking and replacing 02 sensor, new air filter, plugs n leads possibly to.
TB45 stand for Thirsty bastrd 4.5?
I feel a little better now, mines a auto with 305 70`s muds on it and will get well less than 300 around town for 90L of gas and about the same from 85 L of fuel.Plan to shorten the gearing to hopefully improve it as it was way better before the tyres.
Yours needs a tune too. When I swap my standard tyres for 33x12.5/15, I only drop a few extra % beyond the 6% due to different odometer reading caused by the larger tyres. On street tyres I'm getting 400 Km+ around town on a tank of gas. It is a manual though.
This might help...
here are some current figures taken over the last couple of days... Trip was Mackay to Monto... Monto To Nanago.
Travelled 1081 klms and used:183L of LPG and 79L of uleaded... Works out at about 25L per 100. Do keep in mind my truck is a little bigger then the average patrol... and has a touch more wind resistence... look at the pic below.
shane
mines a auto 33''s with all the heavy **** on board and i get 350klms very time to 90litres of gas and around the 400 klms out of 80 litres of petrol and my speedo reads smack on ...
i dont use the overdrive for where i live as it is hilly...
cheers ash
roughly 80-100kms on the sub tank mate.
but just coming back from my fraser trip, i filled up at hervey bay and put 73l in the main tank but the guage only stayed just over 3/4 full.
anyone else had this happen?
Yes a few times... once you drive for a bit it normally settles... also turn off and wait a bit then re start... seemed to fix it a few times as well.
Cheers mate, ill try that next time.
so i just checked the odo readying, 432kms on the main, pretty much hervey bay to rocky plus some around town driving, needle is on E but the light hasnt come on yet.
1 - 18 of 18 Posts
