1 - 3 of 3 Posts
nissan patrol gq
Hi just trying to get some help just done a conversion and have just put in the fuel filter and I'm not sure as to which fuel line runs to it? I have a a large diameter hose and a small diameter hose coming up from the fuel tank.
I'm Guessing the large one runs to the filter then back to the pump and the small one runs straight to the pump as some sort of overflow? Am I wrong?
And I removed the old charcole canister in the engine bay, does anyone know if I just block it off on the tank or do I keep it as a breather?
large one goes to the fuel filter, small one is the diesel return line from the injectors, where the charcoal canister line comes from the tank the diesels have a breather near the filler.
Tim
Reactions: 01cress
nissan patrol gq
So the line to the charcole canister gets plumbed into the breather
Code:
in the fill line or I can block it off due to already having the breather in the tank?
1 - 3 of 3 Posts
