1 - 9 of 9 Posts
Hi all,
Just curious really as to how many years and k's you have got from your injector pump on a TD42 before requiring a rebuild. Trying to get a gauge of what I might be up for over the coming years and how much to expect to spend. Currently got a 2001 TD42T GU with 160k on it.
Cheers,
John.
with clean fuel (replacing fuel filters regularly. i see no dramas with 300000kms or more. the biggest thing is australias very poor diesel and its lubricating properties. with a small dose of something like chemtech diesel fuel additive should reach a pretty high number before any work is required.
as the chemtech adds a lubricant to the fuel again.
Would this be the same for an inline pump?
naturally asthmatic
An inline pump should last a lot longer. Unlike a rotary pump, it doesn't rely on the lubricant in the fuel for lubrication.
TD42 in a 1992(ish) maverick, rotary pump, started weeping from the little side plate at 220,000km.
TD27-T in a 1991 terrano, rotary boost compensated pump started leaking lots of diesel all over the place at 190,000.
TD42 early grey one unknown history but probably 250,000km plus leaked quite a bit.
dirty fuel wont cause leaks, just really bad performance.
TD27-T pump cost something like $1600 for a stock rebuild.
High performance build of a TD42 pump is close to $2500
What causes leaks is they changed the fuel composition on us a few years ago. This causes the old seal material to fail. I don't seem to have much luck with fuel pumps.
Part of the furniture
22 years, and 345 thousand kms later, the pump on the GQ shortys still pumpin..
im guessing she's not as dry as she used to b on the outside,
but the old girl ain't leaking.. very slow weap.
this better not jinx me..
haha
I'll start to worry when the old donk stops going bang!
then she'll be treated to a full rebuild.
My GQ is coming up to 330K and the pump is fine. No leaks, idles smoothly.....touch wood. I do run an additive for extra lubrication..
When is a pump required to be rebuilt?? When it leaks? What other signs do you look out for? Have always wondered this.
naturally asthmatic
Big sign would be a loss of power. Of course that could be a number of things unrelated to the pump. The only way to know for sure is to pull it and put it on a test bench. If the tests bench test shows there are problems, then it gets pulled apart and inspected for wear.
1 - 9 of 9 Posts
