Hi All
If the valve end of your rockers is slightly concave from wear it will be difficult to use a feeler gauge to get the clearance correct. I am sure someone has thought of this before but here goes:
The adjusting thread is M8 x 1, so one full turn = 1mm of travel.
We want 0.35mm, so this would be .35 of a turn. The rocker shaft axis is 25mm from the pushrod end, and 40mm from the valve end, so we only need (25x0.35)/40, which turns out to be 0.21 of a turn - a fifth of a turn.
So for the valve being adjusted:
Can anyone see why this would not work?
The next time I do this I will have a specially marked screwdriver and drilled plate so I know I am getting exactly 0.21 of a turn.
- Back off the lock nut
- tighten the adjusting screw down finger-tip tight only, i.e. to the zero clearance position
- Back off the adjusting screw one-fifth of a turn
- tighten the lock nut, taking care that the adjusting screw does not move.
